파워맥 G4 800 VS 1.25 뭐가 더 나은가요?
팝콘 5 4,877
제가 잘몰라서 여쭙니다..
편집디자인 할때 쓸거구요 쿽 3.3은 둘다 되는건가요..
단독부팅,듀얼의 차이인지..
faf
the <h2><b><a href="http://www.cartierreplicawatch.net/breitling-aeromarine-chrono-colt-steel-black-mens-watch-a7338011-b7-811a-replica-cartier.html">Breitling Aeromarine Chrono Colt Steel Black Mens A7338011-B7-811A</a></b></h2> way of conventional thinking. <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Watch</a></b></h3> The MBA curriculum at INSEAD business <h2><b><a href="http://www.lreplical.com/products/replica-chanel-25173-pink-1485-bags.html">Chanel 25173 Pink-1485</a></b></h2> school has been designed <h3><b><a href="http://www.lreplical.com/categories/fendi-bags.html">Fendi Handbags outlet</a></b></h3> to provide its students the <h2><b><a href="http://www.ireplical.com">designer replica bags</a></b></h2> necessary skills and techniques <h3><b><a href="http://www.ireplical.com">designer handbags</a></b></h3> that help them make a career for <h2><b><a href="http://www.bestswissreplicas.com/replica-panerai-watches-swiss.html">Panerai</a></b></h2> in the international business <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> zone. INSEAD business school <h2><b><a href="http://www.bestwatchesreplica.com/products/iwc-portuguese-iwc-66-546-watch-replica.html">cheap IWC Portuguese IWC-66-546 watch replica</a></b></h2> makes sure that the <h3><b><a href="http://www.bestwatchesreplica.com/categories/jaeger-lecoultre-watches-replica.html">cheap Jaeger-leCoultre watches</a></b></h3> students are exposed to number of <h2><b><a href="http://www.handbagdesigner.net/ysl-handbags-designer-replica-handbags/replica-ysl-handbags-ysl-handbags-designer/replica-ysl-clutch-in-metallic-silver-61401-07-designer.html">YSL clutch in Metallic Silver 61401-07</a></b></h2> different types of work <h3><b><a href="http://www.handbagdesigner.net/louis-vuitton-handbags-designer-replica-handbags/replica-louis-vuitton-handbags-damier-canvas-designer/replica-louis-vuitton-damier-beaubourg-designer.html">LOUIS VUITTON DAMIER BEAUBOURG Handbags knockoffs</a></b></h3> cultures. Students enrolled for
팝콘
답변 감사합니다..
emoticon_096 당연히 1.25 모델입니다....
단독부팅은 MacOS9부팅이 된다는 애기입니다
일부 G4모델과 G5기종들은 MacOS9 부팅이 안되거든요.
듀얼은 CPU가 두개라는 애기죠..하지만 MacOS9로 부팅사용시에는 싱글과 거의 별 차이가 없습니다
이유는 시스템에서 듀얼기능을 제대로 활용을 하지를 못하거든요
MacOS X로 사용시에는 그 차이가 있지만...
G4/1.25기종이 훨씬 빠르고 좋습니다. 듀얼기종은 애플메뉴항목의 시스템 프로필러에서 우측 중간에 기계속도 바로아래 2라는 숫자가 표시되어있으면 듀얼기종이고 없으면 싱글 기종입니다. 참고로 OS9 환경에서는 듀얼과 싱글의차이가 없습니다. OSX환경에서 사용시 듀얼기종의 기능이 발휘됩니다.간혹 G4/1.25듀얼기종중에(1394포트가800인기종)
과 1GB싱글 기종이 OS9 단독부팅이 안됩니다. 참고 바랍니다.
당연이 G4 마지막 기종인 G4/1.25싱글이 더 좋습니다.
싱글은 CPU가 하나고 듀얼은 CPU가 2개 입니다.
그러나 OS X(10)으로 부팅을 했을때만 듀얼로 작동이 되기 때문에 OS 9로 부팅을 해서 사용하는 경우에는 싱글이나 듀얼이나 속도는 같습니다.
또한 OS 9로 바로부팅(단독부팅)이 안되는 기종은 G4/1GHz싱글 전기종과 G4/1.25 듀얼기종중에 일부기종(FW800인기종)입니다.
제품 사양은 아래 링크 참고
http://www.everymac.com/systems/apple/powermac_g4/index-powermac-g4.html
