오버프린트 질문!
오버프린트 질문!
이혜정 7 3,741
별색 베다 위에 012라는 숫자가 있습니다.
0은 먹40%, 12는 먹 100%
이럴 경우 012 전부다 오버프린트 해야 색 제대로 나오지않나요?
저번에 디폴트/0.144로 했다가 녹아웃이 되어서요
replica tiffany
ton enunciated <h2><b><a href="http://www.ebestwatch.com/categories/concord-replicas.html">exact replica Concord</a></b></h2> the law of gravity <h3><b><a href="http://www.ebestwatch.com/categories/rolex-replicas.html">Rolex replica watches</a></b></h3> he did not say <h4><b><a href="http://www.ebestwatch.com/products/breitling-49.html">Breitling Crosswind Quartz Chronometer BREIT-167-130 imitation</a></b></h4> that the sun or the earth had a property of attraction; he <h2><b><a href="http://www.ereplical.com">Buy Replica Handbags</a></b></h2> said that all bodies <h3><b><a href="http://www.ereplical.com/products/chanel-paris-moscou-2008-9-classical-lambskin-bag-with-flap-stit-1195-bags.html">Chanel Paris-Moscou 2008/9 classical lambskin bag with flap stit-1195</a></b></h3> from the largest to <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> the smallest have the property of attracting one another, that <h2><b><a href="http://www.exactreplicas.net">discount rolex replicas watch</a></b></h2> is, leaving aside the <h3><b><a href="http://www.exactreplicas.net">designer replica watches</a></b></h3> question of the cause <h4><b><a href="http://www.exactreplicas.net">cheap replicas rolex</a></b></h4> of the movement of the bodies, he expressed the property <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> common to all bodies <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> from the infinitely large <h4><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-speedmaster-replica-swiss-watches-4553.html">replica Omega Speedmaster 5-counters Mens 321.30.44.52.01.001</a></b></h4> to the infinitely small. The same is done by <h2><b><a href="http://www.bestwatchesreplica.com/products/patek-philippe-sky-moon-tourbillion-dual-side-watch-p-phil-56-822-watch-replica.html">cheap Patek Philippe Sky Moon Tourbillion Dual Side P_PHIL-56-822 watch replica</a></b></h2> the natural sciences: leaving <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> aside the question of <h4><b><a href="http://www.bestwatchesreplica.com/products/breitling-bentley-edition-breit-11-164-watch-replica.html">cheap Breitling Bentley Edition BREIT-11-164 watch replica</a></b></h4> cause, they seek for laws. History stands on the <h2><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h2> same path. And if <h3><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h3> history has for its <h4><b><a href="http://www.handbagdesigner.net/dior-2009-designer-replica-handbags">Dior-2009 handbags</a></b></h4> object the study of the movement of the nations and of h
이혜정
2도인쇄라서 오버프린트 했는데 잘 보이겟지요?
음 제가 말씀드린 녹아웃은 정확히 말씀드리자면 트랩값을 주는것을 말씀드린것 입니다.
녹아웃이란 구멍을 뚫는것이라고 생각하시면되구요 트랩은 녹아웃 된 색이 맞물리는 정도를 말합니다..디폴트/0.144=트랩값
트랩값 설정을 녹아웃으로 해주시면 물리는거 없이 떨어지기때문에 글자 종류는 트랩값을 주시는게 좋을거예요
smc^.^~
원하는게 그거라면 그러긴하겠네요.
별색과 같이 쓰실때는 녹아웃 해주는게 낫지 않나요? 먹 100%면 몰라도 먹40%면 별색색이 먹어서 더 진하게 나올텐데요...음 보통 별색과 먹2도 라면 별색을 CMY중에 하나 들어내고 찍기때문에 먹이 나중에 직혀서 오버프린트 해도 보이겠지만 4도를 인쇄하고 별색을 나중에 찍는 4도인쇄기에 5도로 찍을때는 오버프린트하시면 안되요..반드시 녹아웃해주셔야 됩니다
이혜정
감사합니다~^^
smc^.^~
네
