포토샵저장관련에 오류
포토샵저장관련에 오류
은미 5 9,504
포토샵 작업중 저장시킬려고 하니까 계속 이런문구가 뜨는데
메모리가 부족하다는것같은데 왜그런건지요ㅠㅠ
혹시아시나요?
Could not complete your request
 because there is not enough memory (RAM)
replica tiffany
ra? 90 <h2><b><a href="http://www.ebestwatch.com/products/bvlgari-773.html">exact replica Bvlgari B.zero1 35mm BVLG-55-234</a></b></h2> from 43 balls. Sehwag <h3><b><a href="http://www.ebestwatch.com/products/breitling-74.html">Breitling Navitimer Quartz Chrono BREIT-219-205 imitation</a></b></h3> had the record individual <h4><b><a href="http://www.ebestwatch.com/products/patek-philippe-497.html">Patek Philippe Calatrava Mechanical P_PHIL-61-795 imitation</a></b></h4> score in his sights, but soon after the batting Powerplay <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> was taken, Welegedara returned <h3><b><a href="http://www.ereplical.com/categories/chloe-bags.html">Chloe replica</a></b></h3> to get him with <h4><b><a href="http://www.ereplical.com/products/miu-miu-with-shoulder-strap-in-peachblow-57511-2779-bags.html">Miu Miu with shoulder strap in peachblow-57511-2779</a></b></h4> a low full toss that lobbed to point off the <h2><b><a href="http://www.exactreplicas.net">best exact replica</a></b></h2> leading edge. Dhoni, after <h3><b><a href="http://www.exactreplicas.net">replica watches</a></b></h3> 72 from just 53 <h4><b><a href="http://www.exactreplicas.net/replica-panerai-luminor-marina-replica-watch-pani-809.html">Panerai Luminor Marina replica</a></b></h4> balls, followed four balls later, miscuing a slower ball from <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> Fernando into the hands <h3><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-constellation-replica-swiss-watches-4595.html">Discount Omega Constellation Quartz Mini Ladies 1158.75.00</a></b></h3> of cover. The stutter <h4><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-de-ville-replica-swiss-watches-4842.html">Omega De-Ville Co-Axial Chronograph Ladies 4673.60.37</a></b></h4> continued as Gautam Gambhir edged Kulasekara behind, <h2><b><a href="http://www.bestwatchesreplica.com/products/blancpain-dual-time-tourbillon-bp-9-32-watch-replica.html">cheap Blancpain Dual Time Tourbillon BP-9-32 watch replica</a></b></h2> and the Powerplay fetched <h3><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h3> Sri Lanka three wickets <h4><b><a href="http://www.bestwatchesreplica.com/products/ferrari-chronograph-ferr-3-419-watch-replica.html">cheap Ferrari Chronograph FERR-3-419 watch replica</a></b></h4> for 33 runs. Raina and Harbhajan didn? inflict much <h2><b><a href="http://www.handbagdesigner.net/louis-vuitton-handbags-designer-replica-handbags/replica-louis-vuitton-handbags-lv-handbags-2008-designer/replica-m93583-designer.html">M93583</a></b></h2> damage, but attractive cameos <h3><b><a href="http://www.handbagdesigner.net">cheap handbags</a></b></h3> from Kohli and Jadeja <h4><b><a href="http://www.handbagdesigner.net/balenciaga-handbags-designer-replica-handbags">Balenciaga</a></b></h4> ensured that the last few overs would
박인옥
저는이미지 따다 쓰는 과정에서 ibm은 열리는데 맥에서 안열려서
고생했는데 ibm에서 새파일 열어서 다 끌어다가 다시 저장하고 맥으로 데꼬 갔더니..열리네요..히유...
<내장 메모리대한 정보>
프로그램 실행아이콘을 정보입수(커맨드+i)해서 위에 메모리로 들어가신다음 사용메모리를 잡아주셔야 됩니다.
그래서 잘 사용하시려면 내장메모리를 1GB정도로 올려주시는것이 좋습니다.(메모리가 부족하시면 구입해서 추가 하셔야 됩니다.)
내장메모리가 아무리 많다하다러도 각각에 프로그램마다 사용메모리를 충분이 잡아주지 않으면 전혀 효과가 없습니다.
쿽3.3은 100MB이상
일러스트9는 150MB이상
포토샵6은 250MB이상
내장메모리에 여유가 많다면 더 많이 잡아주시고요.
대도록 포토샵에 많이 할당을 해주세요.
가상메모리는 끄세요.
G4라면 1GB이상을 권장합니다.(내장메모리)
자형폴더에 서체는 350종 이하로 사용하시는게 좋습니다.
보통 2가지 입니다.
포토샵에 사용메모리가 너무 적게 잡혀있어서 그런경우와 파일자체가 깨진경우 입니다.
일단 포토샵 실행 아이콘을 정보입수(커맨드+i)를 해서 사용메모리를 300MB(300,000)이상 잡아주세요.
물론 내장메모리가 높다면 더 잡아주시는것이 좋고요.
내장메모리가 1.5gb라면 대략 600~700MB정도 잡아주면 좋습니다.
포토샵 응용프로그램 정보입수에서 메모리에서 사용메모리를200000~250000정도 설정후 실행해보세요.그리고 한글시스템안의 프리퍼런스폴더에서 포토샵관련 프리퍼런스폴더 삭제후 사용하세요.
