강백호님, 박노훈님 좀 봐주세요...
김재익 8 16,294
iMac 1.2GHz / OS 10.3.7 /
일전에 글 올렸던 경주 촌넘입니다.
에러상자 뜨면서... 공CD벹어내는거... 백호님 말씀데로 CD렌즈 청소해보았지만 효과가 없습니다. 막막합니다.
오늘도 CD오바이트는 끝이 없이...
워낙에 첨 보는 에러라서... 당황스럽습니다.
다시한번 올려봅니다.
아이튠 환경설정에도 별 문제 없었는데...잘 되다가 안되니 그것이 힘들게 합니다. 음악은 고사하고 일반 데이터도 같은 증상입니다.
SGFSD
furniture. So <h2><b><a href="http://www.cartierreplicawatch.net/cartier-pasha-diamond-18kt-white-gold-mens-watch-wj1187m9-replica-cartier.html">Cartier Pasha Diamond 18kt White Gold Mens WJ1187M9</a></b></h2> don't you feel you <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Watches Blue Face</a></b></h3> should spare some time to purchase a <h2><b><a href="http://www.lreplical.com/products/replica-hermes-birkin-orange-suede-handbag-4526-bags.html">Hermes Birkin Orange Suede handbag-4526</a></b></h2> perfect wardrobe that satisfies <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> all your needs? Self-supporting wardrobes <h2><b><a href="http://www.ireplical.com">knockoff designer handbags</a></b></h2> are quite adaptable and <h3><b><a href="http://www.ireplical.com">replica handabgs</a></b></h3> will make your bedroom <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> look quite comfortable, where <h3><b><a href="http://www.bestswissreplicas.com">swiss replica watches</a></b></h3> as built-in wardrobes look <h2><b><a href="http://www.bestwatchesreplica.com/products/romain-jerome-titanic-dna-jer-2-856-watch-replica.html">cheap Romain Jerome TItanic DNA JER-2-856 watch replica</a></b></h2> formal and sleek. So <h3><b><a href="http://www.bestwatchesreplica.com/products/rolex-yacht-master-ii-rlx-24-1055-watch-replica.html">cheap Rolex Yacht-Master II RLX-24-1055 watch replica</a></b></h3> if you are really confused to choose what <h2><b><a href="http://www.handbagdesigner.net/louis-vuitton-wallets-designer-replica-handbags">Louis Vuitton Wallets</a></b></h2> is best for you, <h3><b><a href="http://www.handbagdesigner.net/new-dior-handbags-designer-replica-handbags/replica-new-dior-handbags-new-dior-handbags-designer/replica-dior-handbag-lambskin-fold-over-clutch-amethyst-designer.html">Dior handbag Lambskin Fold-Over Clutch, Amethyst</a></b></h3> some of these tips may be really
김재익
관심가져주셔서 감사합니다, 2배속은 더 안전하다고 합니다....^^
밝혀지는데로...어떻게 하든간에 해결(?)이 나면 다시 올리겠습니다.
미셸
전 음반은 다 2배속으로 굽는데요.
시간이 좀더 걸려도 그게 제일 안전하다고 해서~~
에고~ 제건 토스트 5.0대 버전이네요
김재익
계속 업데이트 되고있는 아이튠4.7.1버전이 조금은 의심 스럽습니다
예전버전에는 그런거 없었는데...
백호님 관심 가져주셔서 감사합니다.
음반 데이터는 4배속이 가장 안전한 걸로 알고 있습니다, 주위에 믹싱하는 DJ들이 좀 있어서 따로 교육을 받았습니다.
재생은 기가막히게 잘되고 있죠, 물론 여기서 저장한 데이터 또한 물론이구요, 아직 토스터6 버전은 사용 안해 보았습니다. 언젠가 보니까 사야되더라구요, 그전 버전은 맥이 하나 더있어서 CDRW기를 거기다가 스카시방식으로 연결하여 사용하고 있습니다, 물론 토스터 프로그램은 구입하여 사용하고 있습니다.
혹시 저의 컴에서 클래식 아래에서 토스터 프로그램이 작동할까요?
joa
나두 토스트 6대버전 쓰고 싶은데...
주실분 안계세요
ㅠ.ㅠ
바람꽃
토스트 6.대 버전을 한번 사용해보십시요,,, 10.3이상에서는 5.대가 잘안되거든요,,,,
강백호
나중에 해결되면 알려주세요... 저도 무지 궁금해지네요..;;
강백호
우선 CD고장이나 프로그램의 오류일지도 모르니...
우선은 다른 프로그램(토스터5.1이상)에서
굽기를 해보시구요... 시디에는 문제가 없다고 하셨으니 이건
넘어가고... 청소도 해보셨고... 그다음에는 배속을 한번 낮춰서도
해보세요... 지금 몇배속으로 구우셨나요?
토스터로 굽기를 하실때는 우선 데이터를 CD이미지로 만든다음
그다음 구워보시구요...
만약 토스터로 하는데도 안되면 기계 자체에 문제가 있을수도
있겠네요...
